Hello!
I have to do the opposite of the usual process, maybe someone can help me...
I have an old step file that is somewhat complex, but I want to pull something simple out of it... here is the rundown of the file. I can't post it so we'll have to go from descriptions....
The part is a roller, say it is 5" OD, 10" long. On the round face of the roller, but only on one side, there is a complex single line pattern. Think of it as text that was layed on to the roller, so it is now 3 dimensional because of the curve. I need that to be extracted back to a 2D path.
Here is what I have done so far:
I created a "sheet metal" cylinder that has the same OD as my roller and overlapped them in the same space, ripped the sheet metal in the back so I could flatten it later. I copied the geometry (using "include geometry") of the path to a new 3d sketch on the face of the sheet metal, and then tried flattening. What I end up with is a nice flat piece of sheet metal, but no geometry. I suppose this is probably expected, since the geometry has nothing to do with manufacturing the sheet metal. However, I need to figure out a way to "flatten" this path. I assume that the geometry is a separate entity from the sheet metal cylinder even though it appears to be on the surface, but I can't figure out how to "attach" it to the sheet metal, even as a sweep or something similar.
Thoughts? I can assure you that it is truly "flat" on the roller, so the only 3rd dimension is the curvature of the roller. Thank you!
Hi sveremey,
I didn't follow everything you typed, but I was able to do something simlar using a Shell feature and Rip feature. Have a look at the attached example model and post back if you can't get your model to work this way.
I hope this helps.
Curtis
Yours works exactly the way I want (I think!)... so, thank you... however I think it is my method of applying the 2d path to the sheet metal that is the issue. I have attached a very simple file that shows how my geometry is applied. This exhibits the same problem I was having, when flattened, that geometry isn't involved.
The way you did it works. Can you tell me how one would go about turning my geometry in to yours? Yours seems to be integrated in to the shell whereas mine is a separate entity.
Thanks for the help, I am new to Inventor and I appreciate the quick assistance.
