Inventor Forum
How to stop chamfer before the corner?
3 REPLIES 3
1827 Views, 3 Replies
I have chamfer going around my part but I need to make it to stop 2mm's before the corner. How is this done?
Googled example for you.
3 REPLIES 3
JDMather
Sweep
Curtis_Waguespack
Hi es12,
As JD mentioned you can use a Sweep feature for this, or you can create an Extrude cut. There are probably some other methods as well. You didn't mention what version of Inventor you're using, but here's an example Inventor 2010 file. Hopefully you can open it.
You might also be interested in Paul Munford's post on this subject:
http://cadsetterout.com/inventor-tutorials/inventor-ifeatures-stopped-chamfer/
I hope this helps.
Curtis
in reply to: JDMather
@Anonymous wrote:
Sweep
Wow, what an inisghtful and helpful response.
