After a slice operation i have to make a sketch and complete lines.
For example, if i slice in the middle of a threaded hole, in the slice i don't see the thread lines, i just see as if there was a hole.
Solved by okaleja. Go to Solution.
Showing thread edges in slice views is not supported. As a workaround you can use a Section view with a very small section depth (e.g. 0.001).
Hope this helps,
Oto Kaleja
