Inventor Forum
How to show the thread boundaries in a section or break out view
1 REPLY 1
Karol-Or
440 Views, 1 Reply
I want that a section parallel and through a threaded hole will show the double lines of the thread.
Now only a hole is shown
1 REPLY 1
mikejones
in reply to: Karol-Or
Is this in a part or assembly file? I've just created a simple part with a tapped hole through it and produced a quick of it with the section view and it shows the thread lines ok. If it is an assembly drawing that you're sectioning then you would need to specify that thread lines are shown. This is done through the 'edit view' dialogue box on the 'Display Options' Tab.
Hope that helps.
Mike
Autodesk Certified Professional
