Inventor Forum
How to remove a piece from object
3 REPLIES 3
PPisano
486 Views, 3 Replies
I have this obect (see attached IPT) with a piece that is cut off from the main object but I can't figure out how to remove it (the piece in the top left in front view).
Thanks for your help.
3 REPLIES 3
blair
in reply to: PPisano
Like this?
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
PPisano
in reply to: blair
Thanks Blair,
Perfect solution!
karthur1
I see that Blair has already replied.... but a another way to remove this is to use the "Delete Face" command.
From the Surface panel, pick delete face.  Change from the "Individual faces" to the "Select Lump or Void".  Pick the part you want to remove... Done.
No work planes to create, no extrusion command.... Simple.
