I had a hydraulic hose connected to an elbow fitting and now it has been changed a straight fitting.
What is the proper way to do this so that it is still adaptive?
And how can I reconnect the hose to the new fitting and have it adaptive?
Thanks in advance
hope to get an answer before I pull out my greying hair.
Inventor 2012
Solved by alessandro.gasso. Go to Solution.
I hope at least one of the two ways you can see in the attached video could help.
By the way, in general, if you replace the fitting, selecting it in the browser, right-click, and using the command Replace from Content Center, you should not lose the connection with the hose.
Kind regards,
Alessandro
