I derived a part and added extrusion.
The original part is rotated at an arbitrary angle and i want to align the origin planes differently.
Can i do that?
Use the Move Bodies command.
You can translate (straight line) and rotate the part as needed.
You might do a search on Move Bodies here as there is a trick to Rotate.
See Response #2 here http://forums.autodesk.com/t5/Inventor-General/Rotate-trace-geom-of-one-part-on-plane-cant-delete-po...
