Inventor Forum
How to print 2d sketch?
16 REPLIES 16
Message 1 of 17
6408 Views, 16 Replies
I need to print an initial 2d sketch (without any 3d work done on it).
Printing this in sketch mode seems to output a screen capture, i.e. some lines appear wriggly and not as precise as an ordinary plot of an idw or dwg file.
A sketch w/o any 3d work will not be accepted as an idw file, thus I am not able to use all the formatting (tblocks, fonts, dimstyles, etc.) options available to idw files.
Is there a way of printing a 2d sketch (w/o any 3d work) as an idw file?
Thanks for any help.
16 REPLIES 16
Message 2 of 17
Not sure what your problem is.
Been doing the following:
1) Tools/Application Option/Color Change the background color 1
Color,
    mat have to utilize Color Scheme: Presentation.
2) File/Print Setup, Set up your printer to desired paper size and
orientation.
3) File/Print Review, check it out.
4) File/Print or Ctrl+P.
Let me know if you have any other problems
Wolfe
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">I
file.
Message 3 of 17
1) Make your sketch
2) Return out of sketch mode
3) Right click on sketch name and selct 'Copy'
4) Open a blank drawing
5) Go to sketch mode
6) Right click in drawing area
7) Paste
8) Return out of sketch mode
The drawing will be down in the left corner but you can drag it to a new
location. Also, the dimensions will be gone but you can add then as in a
regular drawing.
This method is also useful to get a very clean 2D drawing into CAM programs.
If you don't move the drawing the center will come in at 0,0 in CAM.
Message 4 of 17
I just found a way to get the dimensions too. Right click on the drawing
and choose Retrieve Dimensions. Pick the ones you want and Apply.
Message 5 of 17
Thanks a lot for the replies Wolfe and Roger.
Wolfe, when you print the ipt file this way, does your plot turn out with the same quality as a plot from an idw or dwg file?
Mine turns out with soft (not crisp) lines, especially on those geometries which are apparently computed by the program, like circles, ellipses, polygons, etc.
I am printing with an HP laser printer and it has always printed all idw or dwg files clearly.
I was hoping that I can do my 2d plotting on IV altogether, without having to go back to Acad/idw for printing. But I can't get IV to print well directly from an ipt file.
Is this a limitation of the program? its settings? HP printer?
Would appreciate any help.
Message 6 of 17
I've never printed from sketch geometry.
All I've done in the past is made an extrusion (1mm, 2mm, whatever) and the
placed the solid in the drawing.
That way all is fine when printing. Your problem is probably because sketch
geometry is not a solid line as IV sees it. (Solid as in belonging to a
solid feature).
______________
Rui
www.cadmais.pt
"elucero" wrote in message
news:f1a1ba0.3@WebX.maYIadrTaRb...
polygons, etc.
Message 7 of 17
Hello Rui,
I also think this is the case. So it seems to get a clear/crisp print of a sketch, you do have to pass it through idw as a solid first.
Thanks again.
Message 8 of 17
My plotter is HP Laserjet 5100, the dimension may be not very clear
depending on the plot size.
You may have to experiment with the background colors
to get a good plot.
Have no problems here otherwise.
Hoping this will help.
Wolfe
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">Thanks
polygons, etc.
dwg files clearly.
from an ipt file.
Message 9 of 17
A print of a thin solid and the sketch are not always the same. The sketch
method (see my other posts in this thread) will be better at times. It will
depend on what sketch details are important. Both methods will give the
same print quality. The top image in the attachment shows the sketch copied
and pasted to an .idw and the bottom image is of a thin extrusion.
Message 10 of 17
Hi Roger,
Your method produces the clear prints I need. Too bad, you have to go through this roundabout way.
Thnx for the tip.
Message 11 of 17
Thanks for the advice people.  I have also been having this problem.  I may be crazy but surely the whole point of designing something in this fancy program is so that someone will build it at the end - how the hell they are supposed to do that if they can't easily print out sketches from the models is anybodies guess.
As a recent user of this program and CAD in general I guess i' might be missing something but I feel it's a severe limitation if you can't print out a decent plan to bring down to the workshop.
Message 12 of 17
SBix26
The workflow in Inventor, as well as in most (all?) other 3D modelers, is to create the model (3D), then create drawings to document the model (2D).  In Inventor, the 3D model is created from a series of 2D sketches that are revolved, extruded, swept, lofted, etc. and modified with holes, fillets, chamfers, drafts, etc.  Then create a drawing (.idw or .dwg) and place various views of your model and annotate them.
This is a very old thread that you're replying to, and the software has changed a bit since then.  Unless you're using version 8.0 or less, you might want to ask your question in a new thread.  Model sketches now can be displayed in drawings, and if the only thing in your model is a sketch, that is automatically displayed when you create a view normal to the sketch.  Oh, and be sure to let us know what version of the software you are using.
Message 13 of 17
in reply to: SBix26
Thanks for the reply.
I am working with Autodesk Inventor Professional 2013 (but the 'student licence' version of the professional)
I've followed on from this thread - since I googled "how to print 2d sketch" in the first place.  Probably this thread is where i would end up again if I was still looking.
I made some revolutions of a 2D schetch to make a 3d sketch of what are effectively a set of spools, with groves etc cut into them.  Clearly the 2D sketch  defining the cross section that I made to originally revolve into the 3d sketch are the definition of the shape I need to create in real life.  My question is - what is the best way to export them to some sort of printable format.
If I expand the revolution, open the sketch, and then click export it pops back to the model view.
If I write click on the sketch there is an option to export, although when i have opened the dwg file that is created, it simply is a black outline - without any of the dimensions on it - which is what i've spent the time defining.
I followed the advice earlier in this thread about copying the sketch and dumping it into another drawing, which works. kind of.... -but clearly this is a bit of an inefficient and un-joined up  way of doing it.  Copying and pasting graphics around reminds me of using paint.  My question is what is the proper way of doing it....
(and question part B - for lazy people like me who simply want a screen shot of the 2D drawing output to a picture\pdf file what is the easy way of doing it within Inventor - without having to create another file for each sketch - are there some options I've missed.)
JP
Message 14 of 17
Ray_Feiler
Create a IDW or Inventor DWG 2D drawing of your 3D part. Make sure the sketch you wish to see is normal to the view you create. Right click on the view in the browser and select Retrieve Dimensions and then click on Selcet Dimensions. Select the dimensions you wish to retrieve.
Product Design & Manufacturing Collection 2024
Sometimes you just need a good old reboot.
Message 15 of 17
Ray_Feiler
From the 3D model go to Application Options Colors tab and select Presentation then click on Apply. Make your sketch visible and normal to the display then click on the print icon.
Message 16 of 17
SBix26
An Inventor Drawing is the way to document a design.  The drawing can be either a .idw or .dwg format.  Create a new drawing file, then place a base view of your model.  Then place projected views from the base view.
Now use the tools on the Annotations tab to annotate it.
I strongly discourage dimensioning your model sketches as if they are drawings.  Many times the design intent, captured in the modeling process, is not the same as the manufacturing/fabrication dimensions that are needed in the drawing.  Modeling symmetrically around the centerline of a part is good modeling practice, but in most cases it's not good drawing practice to dimension to a symmetry line which doesn't actually exist as a feature.
Message 17 of 17
in reply to: SBix26
Thanks for the advice everyone!
JP
