Inventor General Discussion
Active Member
hungsianglim
Message 1 of 7 (1,594 Views)
How to make symmetrical line available from the linetype?
1594 Views, 6 Replies
11-10-2012 03:36 AM
Hi there,
In our work we draw many symmetrical outlines.  In many cases, chiefly due to space constraint, we draw only half the outline and use a centerline of the symmetry to dimension the part.
Our current method is to use sketches to achieve this.
I wonder if there is a way that we can make this linetype available from the styles?  Diagram attached below.
Many thanks.
Cheers,
H.S.
*Pro
sbixler
Message 2 of 7 (1,569 Views)
Re: How to make symmetrical line available from the linetype?
11-11-2012 03:50 PM in reply to: hungsianglim
Create a work axis in the model, then right click on the component in the drawing view browser and select Include Work Features; you then have a choice of what kinds of features to include.  This will show your work axis as a centerline.
Product Support
jingy
Message 3 of 7 (1,563 Views)
11-11-2012 08:16 PM in reply to: sbixler
As  said, in the sketch, you could draw a line to creat the center line.
To annotation in the drawing, you could use crop operation, then add a axis in hte crop operation view, and annotae in the symmetrical.
By the way, there is a limitation for the symmetrical symbol. You have to use sketch in the drawing to create it.
Yong Jing
Product Support Specialist
Frontline Technical Support, CSS. GCSO
Active Member
hungsianglim
Message 4 of 7 (1,516 Views)
11-12-2012 08:28 PM in reply to: sbixler
Thanks Sam.  Sorry for not being clear about the problem.
Actually I am able to get the centerline of the part itself (using automoted centerline), but the problem is with the centerline, i.e. the symbol.
I am using sketch to annotate the symbol but to do it on thousands of drawing...
Many thanks!
H.S.
Active Member
hungsianglim
Message 5 of 7 (1,515 Views)
11-12-2012 08:31 PM in reply to: jingy
Hi Yong Jing,
That's exactly what I'm currently doing.  If the number of drawings is small I can live with it but what I really like to do is to have this enforced as part of the company-wide drafting standard so that all drawings will carry the same look.
Wish list?
Cheers
H.S.
Product Support
jingy
Message 6 of 7 (1,507 Views)
11-12-2012 09:49 PM in reply to: hungsianglim
I have logged a wsihlist to the Dev team.
Before it has accepted, you could customized the symbol in the drawing template, then you could insert the customized symbol whenever you need.
Yong Jing
Active Member
hungsianglim
Message 7 of 7 (1,474 Views)
11-16-2012 05:11 AM in reply to: hungsianglim
Many thanks!
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
