Inventor Forum
How to make all imported parts to be opened as Purchased by default?
10 REPLIES 10
Message 1 of 11
Orest_iy
407 Views, 10 Replies
Hello
Orest Yavtushenko
10 REPLIES 10
Message 2 of 11
mcgyvr
in reply to: Orest_iy
I don't think that is possible.
Message 3 of 11
Orest_iy
in reply to: mcgyvr
Imported parts are mostly purchased.
At least mine are 99.9% purchased.
Than will be some wrestling with Inventor to
turn them back to Purchased since it is tooo relactant to
do so just in straight way in some cases
Message 4 of 11
mcgyvr
tools..document settings..bill of materials tab.. change default bom structure to purchased. Not that hard at all really.
Takes a few seconds.
Message 5 of 11
alessandro.gasso
Hi Orest,
Actually, when you import an iges or step file as an Inventor part, the Default BOM Structure is the one of the Standard.ipt template.
So, if you want, you can create a new template, setting the Default BOM Structure to Purchased, name it, for instance, Standard_.ipt template and save it in the Template folder, of course.
Then, before to import the parts, in Windows Explorer, browse to the Templates folder and rename the Standard.ipt template to, for instance, Standard.bak and remove the underscore from the Standard_.ipt, naming it Standard.ipt.
Once you have finish to import the parts, you can restore the original Standard.ipt template.
Of course, it’s up to you to decide, according to your needs, if it’s more convenient for you to follow the suggestion from mcgyvr or this alternative way.
Kind regards,
Alessandro
Alessandro Gasso
Fusion 360 – Simulation/Generative Design Adoption Specialist
Autodesk, Inc.
Message 6 of 11
Hi orest_iy,
I do much the same thing with many imported parts, but use a small iLogic rule to set the BOM structure as mcgyvr suggests. You can just paste this code into a new ilogic rule and then run the rule after you import a part. I typically do this kind of thing as an external rule, that way it's avalible to be run on any part file I want.
Here's a great article on working with rules from Paul "the CAD Setter Out" Munford:
http://www.augi.com/library/playing-by-the-ilogic-rules
I hope this helps.
Curtis
Dim oDoc As Document
oDoc = ThisApplication.ActiveDocument
Dim oCompDef As ComponentDefinition
oCompDef = oDoc.ComponentDefinition
'kDefaultBOMStructure = 51969
'kNormalBOMStructure = 51970
'kPhantomBOMStructure = 51971
'kReferenceBOMStructure = 51972
'kPurchasedBOMStructure = 51973
'kInseparableBOMStructure = 51974
'kVariesBOMStructure = 51975
oCompDef.BOMStructure = 51973
Message 7 of 11
Orest_iy
in reply to: mcgyvr
You mean few second each
it could be 10-20 pieces a day plus changing Part Number which usually not follows the file name .. so really creative way of construction
Message 8 of 11
Curtis
Your advise is the best one so far. Yes the rule is changing newbie or any other ipt to Purchased.
There are two additional things which could make this rule the GREAT.
Is it possible to make a custom button in Model ribbon and assign this rule to it? (Like in AutoCAD?)
The user is mostly work in Model and making one click he could get the happines of changing part status to
Purchased and not going to Manage - ilogic and etc - ie clicking comparable amount of buttons vs going tools -Doc Settings.
The second possible contribution is changing the Part Number to File Number.
Mostly Imported parts has some mess with that and it is also annoying changing or at least checking that
Orest
Message 9 of 11
Hi Orest_iy,
Here is the ammeded code, it will pull the file name into the input box and allow the user to accept it as the part number or change it to something else.
As far as making a button, the best way to do this is to create a button on the iLogic browser panel (assuming you're using Inventor 2012). I'm not aware of a way to add an iLogic button to the ribbon, but I know it's been requested in the past.
I hope this helps.
Curtis
PN = InputBox("Accept the File Name as the Part Number or Enter a new one:", "iLogic", ThisDoc.FileName(False))
iProperties.Value("Project", "Part Number") = PN
Message 10 of 11
Yes it works
I can do it even for any other file as external rule, guess it is 2012 feature
Looking for creating the buttond in web to make a whole happiness in this question
Orest Yavtushenko
Message 11 of 11
Curtis
I just mix both rules together and found the custom button creation
It actually not new one but can retreive the existing, for instance iLogic browser in Model ribbon
(Customize and than add requested button to desired ribbon)
So here is desired GREAT button, I click on mixed rule and my part is Purchased and retreives the file name.
It can be aplicable to all files as External rule
today it was twenty pieces from catalogue, I am designing the new stuff and finally there are just couple
exported parts left in project but all of them I clicked to change status and PartNumber ... toooo boring
Thanks again,
Orest
