Inventor General Discussion
Distinguished Contributor
Orest_iy
Message 1 of 11 (226 Views)
How to make all imported parts to be opened as Purchased by default?
226 Views, 10 Replies
12-09-2011 06:24 AM
Hello
Orest Yavtushenko
mcgyvr
Message 2 of 11 (222 Views)
Re: How to make all imported parts to be opened as Purchased by default?
12-09-2011 06:44 AM in reply to: Orest_iy
I don't think that is possible.
Down with IDW/DWG files..... Long live 3D PMI... Hurry it up already..
2015 Product Design Suite Ultimate
Windows 7 64 bit
Core i7 4820k processor (OC'd to 4.4Ghz), Nvidia GTX 770, 16G RAM
Orest_iy
Message 3 of 11 (219 Views)
12-09-2011 06:53 AM in reply to: mcgyvr
Imported parts are mostly purchased.
At least mine are 99.9% purchased.
Than will be some wrestling with Inventor to
turn them back to Purchased since it is tooo relactant to
do so just in straight way in some cases
mcgyvr
Message 4 of 11 (215 Views)
12-09-2011 06:54 AM in reply to: Orest_iy
tools..document settings..bill of materials tab.. change default bom structure to purchased. Not that hard at all really.
Takes a few seconds.
Windows 7 64 bit
Product Support
alessandro.gasso
Message 5 of 11 (207 Views)
12-09-2011 07:21 AM in reply to: Orest_iy
Hi Orest,
Actually, when you import an iges or step file as an Inventor part, the Default BOM Structure is the one of the Standard.ipt template.
So, if you want, you can create a new template, setting the Default BOM Structure to Purchased, name it, for instance, Standard_.ipt template and save it in the Template folder, of course.
Then, before to import the parts, in Windows Explorer, browse to the Templates folder and rename the Standard.ipt template to, for instance, Standard.bak and remove the underscore from the Standard_.ipt, naming it Standard.ipt.
Once you have finish to import the parts, you can restore the original Standard.ipt template.
Of course, it’s up to you to decide, according to your needs, if it’s more convenient for you to follow the suggestion from mcgyvr or this alternative way.
Kind regards,
Alessandro
Alessandro Gasso
Product Support Technical Lead
MFG - Inventor
Curtis_Waguespack
Message 6 of 11 (199 Views)
12-09-2011 07:51 AM in reply to: Orest_iy
Hi orest_iy,
I do much the same thing with many imported parts, but use a small iLogic rule to set the BOM structure as mcgyvr suggests. You can just paste this code into a new ilogic rule and then run the rule after you import a part. I typically do this kind of thing as an external rule, that way it's avalible to be run on any part file I want.
Here's a great article on working with rules from Paul "the CAD Setter Out" Munford:
http://www.augi.com/library/playing-by-the-ilogic-rules
I hope this helps.
Curtis
Dim oDoc As Document
oDoc = ThisApplication.ActiveDocument
Dim oCompDef As ComponentDefinition
oCompDef = oDoc.ComponentDefinition
'kDefaultBOMStructure = 51969
'kNormalBOMStructure = 51970
'kPhantomBOMStructure = 51971
'kReferenceBOMStructure = 51972
'kPurchasedBOMStructure = 51973
'kInseparableBOMStructure = 51974
'kVariesBOMStructure = 51975
oCompDef.BOMStructure = 51973
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
Orest_iy
Message 7 of 11 (194 Views)
12-09-2011 08:08 AM in reply to: mcgyvr
You mean few second each
it could be 10-20 pieces a day plus changing Part Number which usually not follows the file name .. so really creative way of construction
Orest_iy
Message 8 of 11 (177 Views)
12-09-2011 09:08 AM in reply to: Curtis_Waguespack
Curtis
Your advise is the best one so far. Yes the rule is changing newbie or any other ipt to Purchased.
There are two additional things which could make this rule the GREAT.
Is it possible to make a custom button in Model ribbon and assign this rule to it? (Like in AutoCAD?)
The user is mostly work in Model and making one click he could get the happines of changing part status to
Purchased and not going to Manage - ilogic and etc - ie clicking comparable amount of buttons vs going tools -Doc Settings.
The second possible contribution is changing the Part Number to File Number.
Mostly Imported parts has some mess with that and it is also annoying changing or at least checking that
Orest
Curtis_Waguespack
Message 9 of 11 (167 Views)
12-09-2011 09:51 AM in reply to: Orest_iy
Hi Orest_iy,
Here is the ammeded code, it will pull the file name into the input box and allow the user to accept it as the part number or change it to something else.
As far as making a button, the best way to do this is to create a button on the iLogic browser panel (assuming you're using Inventor 2012). I'm not aware of a way to add an iLogic button to the ribbon, but I know it's been requested in the past.
I hope this helps.
Curtis
PN = InputBox("Accept the File Name as the Part Number or Enter a new one:", "iLogic", ThisDoc.FileName(False))
iProperties.Value("Project", "Part Number") = PN
Orest_iy
Message 10 of 11 (161 Views)
12-09-2011 10:24 AM in reply to: Curtis_Waguespack
Yes it works
I can do it even for any other file as external rule, guess it is 2012 feature
Looking for creating the buttond in web to make a whole happiness in this question
Orest Yavtushenko
