Inventor Forum
How to flatten an elbow like a sheet metal development
10 REPLIES 10
Message 1 of 11
WillieArolf
1879 Views, 10 Replies
I have an elbow with a slit on the other side and would like to use Flatten feature in sheet metal. How do I do it? I tried but an error pops-up, and I do not have an idea does it mean.
I have attach the file.
Maybe, anybody has a workaround if Inventor can not make it. Appreciate your assistance.
Thanks & Regards,
Willie
Autodesk Inventor Professional 2019
Windows 7, 64-bit
10 REPLIES 10
Message 2 of 11
mpatchus
in reply to: WillieArolf
See attached part.
Creating the sheet metal part using the available tools will usually result in a decent flat pattern.
Sometimes it hit or miss, at least in my experience.
Mike Patchus - Lancaster SC
Inventor 2025 Beta
Alienware m17, Intel(R) Core(TM) i9-10980HK CPU @ 2.40GHz 3.10 GHz, Win 11, 64gb RAM, NVIDIA GeForce RTX 2080 Super
Did you find this reply helpful ? If so please use the Accept as Solution or Kudos button below. 🙂
Message 3 of 11
JDMather
How will the part be manufactured?
Can you post a picture of an actual finished part?
The CADWhisperer YouTube Channel
Message 4 of 11
WHolzwarth
This is a pretty good example, that people shouldn't trust very much in Inventor's Flat patterns, that are made from contour roll.
Walter
Walter Holzwarth
Message 5 of 11
WillieArolf
in reply to: mpatchus
Hi Mike,
Thank you for the assistance.
Is that the correct shape "Rectangle" after invoking the Flatten feature?
I thought there should be a slope kinda shape.
Thanks & Regards,
Willie
Windows 7, 64-bit
Message 6 of 11
WillieArolf
in reply to: JDMather
Hi JD,
The part is made of a flexible jacket (I think you have already encountered this issue before)... I am just looking for an alternative way in making use of Inventors ability in creating flat patterned using the sheet metal development.
Honestly, I am trying my best to convience my boss that we should stick in Inventor rather than shifting to solidworks. For the reasons that I am ever since a user of Autodesk products and pretty much used to its features and commands.
But, when it comes to flatting an elbow like shape, I do not know how to defend it.
That is why, I am trying my best to look for any alternative solutions by of course using Inventors ability.
Thanks & Regards,
Willie
Windows 7, 64-bit
Message 7 of 11
JDMather
@WillieArolf wrote:
Honestly, I am trying my best to convience my boss tha....
Have your boss invite a VAR to demonstrate this same part in SolidWorks.   Smiley LOL
Message 8 of 11
RobJV
Buy this program - cheap and they did have it free for 2011.  Not a salesman - just a user.  Download a trial and take a look.
http://www.ductpro.net/
Message 9 of 11
WillieArolf
Hi JD,
One of my collegue who is so eager to acquire solidworks (well, for the reason that he does not know how to use Autodesk Inventor) did brought my boss to one of the talks in solidworks and they have indeed should him that solidworks can do the sheet metal development after they flatten an object.
But, I did told my boss that they may have used a plug-in or third party software to the job. That is why I am asking for an alternative solutions like a plug-in for Inventor to the job.
Thanks & Regards,
Willie
Windows 7, 64-bit
Message 10 of 11
WillieArolf
in reply to: RobJV
Hi RobJV,
Thank you for sharing this, I will try to DL the trial and look onto it.
Thanks & Regards,
Willie
Windows 7, 64-bit
Message 11 of 11
WillieArolf
Hmmmm... wondering if Autodesk already has a good answer to this query.
Thanks & Regards,
Willie
Windows 7, 64-bit
