Hey there
There are many guides, but all of them are confusing.
I made this part, but I have no idea how to measure the weight. I chose the right type of stainless steel and the part is perfectly to scale. What is the overall weight?
[IMG]http://i.imgur.com/1CttvmN.png[/IMG]
Please walk me through all of the steps?
If you would like, I can attach the part and have yourselves do it?
Solved by Cadmanto. Go to Solution.
If you RC on the part in the browser.
Then once in iProperties
Select "Update" and your weight will show up here.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
You're welcome. If you want this weight tied into your drawing you can associate it with a property then link that to a line of text in the drawing.
You can even have this weight show up in your parts list as well.
