Is it possible to search & find where a dimension listed in the parameters dialog occurs in a part model ( in which sketch for example)?
Gary
Solved by Dennis.Ossadnik. Go to Solution.
Hi Gary,
Not sure if I understood the question correctly, but if you hover over the model parameter in parameters dialog, you get the info by which sketch the parameter is consumed:
Is this the information you were looking for? Or are you looking for anything different?
No
I want to find d# in sketch in inventor easily
if I have very dim in a sketch , I want to find it easily and dont wast my time
but your method only show your d# parameter is in which feautre
thanks for your answer
