Open the VBA Editor from Inventor/Tools.
Inside the Vba editor, select Tools-> References from the menu.
Check the Microsoft Excel Object Library
Sub ExportWorkpoints()
Dim oDoc As PartDocument
Set oDoc = ThisApplication.ActiveDocument
Dim oDef As PartComponentDefinition
Set oDef = oDoc.ComponentDefinition
Dim oWorkpoints As WorkPoints
Dim oWP As WorkPoint
Dim oP As Point
'get all workpoints in this part
Set oWorkpoints = oDef.WorkPoints
'create a new excel workbook
Dim oBook As Excel.Workbook
Set oBook = Excel.Workbooks.Add()
Dim oSheet As Excel.WorkSheet
Set oSheet = oBook.ActiveSheet
Dim nRow As Integer
nRow = 1
'write the coordinates into separate columns, one workpoint each row
For Each oWP In oWorkpoints
Set oP = oWP.Point
oSheet.Cells(nRow, 1) = oP.X
oSheet.Cells(nRow, 2) = oP.Y
oSheet.Cells(nRow, 3) = oP.Z
nRow = nRow + 1
Next
oBook.SaveAs ("c:\test.xls")
End Sub
Hope this helps,
Gerald
Gerald Hochenauer(gerald.hochenauer@autodesk.com)
Inventor Principal Software Engineer
Manufacturing Group
Id like to know more about this if possible? Could you give more detailed instructions please? Ive opened the VBA editor, checked excel object library but when i enter the text in a new module and try to run it, it comes up with an error.
Thanks, Dan
Dan,
I need some info on the error you are seeing in order to be able to help. What line of the code? What's the error message?
Gerald
Gerald,
It says "Compile error: User-defined type not defined"
If i click "ok" it then highlights the line of code "oBook As Excel.Workbook"
Does that help?
Im creating the module under "Document Project"
Thanks.
Sorry, that was the wrong one actually! Id forgotten to check excel object library.
With that checked it now reads "run-time error '13': Type mismatch" If i click debug, it highlights the line "Set oDoc = ThisApplication.ActiveDocument"
Any ideas?
Thanks, Dan
Are you running this from within a part document?
It's an assembly, but only with <20 parts. Will it only work on a part document then?
The example I wrote is for a single part document - it is a generic example that takes workpoints within this part and exports their locations.
as opposed to
Dim oDoc As AssemblyDocument
In order to extend the sample to assemblies, you'd have to iterate over the assembly component Definition structure(Assemblies can contain sub assemblies,....) .
You'd need to know about Component Occurrences and transformations in order to get all the points to show up at the assembled locations.
Unfortunately I can't spare the time to write it - I need to wrap up things before leaving on a 3 week business trip. Maybe somebody else can pick it up or you get some training. It is quite a good example to learn how programming Inventor with VBA works.
Gerald Hochenauer
You could do a Derive Part and choose the assembly. Then you could run the code on the Derived Part.
Mike
I have tried to apply this module to single part document however an error comes up:
Run Time Error 91
Object variable or with block variable not set
and after debug this line is highlighted: Set oDef = oDoc.ComponentDefinition
Could you please explain what i'm doing wrong.
From your description it sounds like oDoc has not been assigned.
Please make sure that oDoc is spelled the same everywhere. It might be case sensitive if 'Option Exlicit' is not stated on top of the page.
Gerald
Dear Sir,
I am now getting another error stating:
Upon debugging the following line is highlighted:
Thank you for you support,
Kyra
The save operation fails for probably one of the reasons outlined in the error dialog message.
Please make sure that the .xls file does not exist prior to running the vba macro, and manually delete it before each new run. Close excel as well. Alternatively you can extend the code to handle such cases - it should be possible with some VBA training.
kind regards,
Gerald
