Inventor Forum
How to edit qty field in BOMs ?
2 REPLIES 2
128 Views, 2 Replies
I've been meaning to air this one for a while, but not got around to it.
In a partslist, where you call up items like hose, glue wire etc, you want
the qty field to either include units (2 metres, inches etc) or a/r (as
required) for things like glue or grease.
What do other folk do about this?
tia,
John
2 REPLIES 2
How are you adding things like glue etc. If in the parts list I select Add row I am able
to enter what ever I want in the Qty field. And then just use the custom option on
placing balloons if you need them.
Kent
Assistant Moderator
Autodesk Discussion Forum Moderator Program
"John Ricketts" wrote in message
news:D54E5AE31840A7F2F8BD8308BEEB3636@in.WebX.maYIadrTaRb...
> tia,
> John
Thanks. Yes, that works, but I would rather have dummy parts though, that
you can drop into an assembly for such items. That way, you can just scroll
through the library, find the right glue/grease and drop it in (with it
appearing A/R in the qty field). For cables and hoses I drop in a short
length, then make the parts list entry invisible and drop in a custom with
the length entry but it seems a bit kludgy somehow.
Kent Keller wrote in message ...
row I am able
option on
>Kent
>Assistant Moderator
want
>> tia,
>> John
