Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
How to create an iLogic rule to measure between 2 planes
2 REPLIES 2
2462 Views, 2 Replies
How to create a measurement between two planes using ilogic rules?
I have created the planes on the asssmbly parts but dont know how to directly pick them.
The measurement is going to be used as reference dimension
2 REPLIES 2
Curtis_Waguespack
Hi WEZ69,
Here is a  quick example rule that allows the user to select from a list:
'Dim oDoc As AssemblyDocument
'oDoc = ThisApplication.ActiveDocument
Dim MyArrayList As New ArrayList
'look at the workplane collection
'and add each workplane to the select set
For Each oWorkPlane In ThisDoc.Document.ComponentDefinition.WorkPlanes
'filter out the origin planes
If oWorkPlane.IsCoordinateSystemElement = False Then
'add planes to list
MyArrayList.add(oWorkPlane.Name)
Next
'select first plane to use
oWorkPlane1 = InputListBox("Select the 1st plane to use from the list.", MyArrayList , MyArrayList.item(0), "iLogic", "Workplanes")
'select second plane to use
oWorkPlane2 = InputListBox("Select the 2nd plane to use from the list.", MyArrayList , MyArrayList.item(1), "iLogic", "Workplanes")
'get distance
myDistance = Measure.MinimumDistance(oWorkPlane1, oWorkPlane2)
'display distance in cm's
MessageBox.Show(myDistance & " cm", "iLogic")
'display distance in inches
MessageBox.Show(myDistance * 0.393701 & " in", "iLogic")
Also, if you know the names of the planes ahead of time you could just use something like this example:
'get distance between named work planes
myDistance = Measure.MinimumDistance("Work Plane2", "Work Plane5")
Keep in mind that in the future you might have better luck searching and asking questions of this type on the Inventor Customization forum:
http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/bd-p/120
I hope this helps.
Curtis
Nice,
Is there a way to have a parameter, that after this code remains linked to the distance between then?
Tiago Figueiredo
