Inventor Forum
How to create a rule that alerts if features clash
1 REPLY 1
231 Views, 1 Reply
I want to create a rule that will show the user an alert if certain features clash/interfere with each other. i.e. If two holes cross paths this will trigger the alert.
Is there a built in flag for this in Inventor (2014)?
Andy
1 REPLY 1
Curtis_Waguespack
Hi ak_cryo,
It sounds like AutoLimits would work for you. Note that you might need to go to the Addins tab and ensure that you have AutoLimits turned on:
Create AutoLimits in design
http://help.autodesk.com/view/INVNTOR/2014/ENU/?guid=GUID-41AD332F-81FB-4C2D-8185-DDBA3C5B492E
The other option would be to create a reference dimension between the holes, and then create an iLogic rule to monitor that dimension.
I hope this helps.
Curtis
