Solved by JDMather. Go to Solution.
Is the curve a helix?
Use the Coil command.
Attach your attempt here.
I attached the file as you asked. The objective was to make a 180º curved ramp. In the file you will find my atempt. I was not able to make it grow any further.
Regards.
I got lost on the first sketch.
Can you explain where the dimension for the 2mm circles comes from (see attached)?
I already managed to do the total ramp but with stairs. I wanted this ramp to be smooth. I attached the file.
Thanks for the help.
Best regards.
I am having great difficulty understanding your design intent - but maybe something like attached?
Where i have the steps in the previous attachment i would like to have something like this http://archicad-talk.graphisoft.com/files/thumbs/t_roofs_curved_ramp_15_208.jpg.
Regards.
Isn't that what I attached?
Hi! I played around with it for a few minutes and came up with this solution using Rect Pattern along Helical Path workflow. Please take a look and see if it works for you.
Thanks!
Yes, I'm sorry. I haven't seen the attachment.
Thanks for your help and time. I will now study your process.
Best Regards.
Hi.
I had already done something like you describe here. But the objective was to get a smooth ramp. The previous comment answered my question.
Best regards.
