I am trying to copy a part that is in my assembly drawing and then place multiple instances of that part at equally spaced distance between each other. I can copy the part but i don't know how to place the copied part at the distance i want to place it in. Any help is appriciated, thanks.
Solved by cbenner. Go to Solution.
When you say assembly drawing, I assume you mean assembly model? You copy the part and then place it and control the location with assembly constraints, then you can use a pattern to get the rest.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
