Inventor Forum
How to convert from mm to Inches
42 REPLIES 42
Message 1 of 43
gphillips
31106 Views, 42 Replies
If I have something that was designed in mm and should be in inches, how do you convert it. What I mean is, I have a part that should be 26 inches long but it is 26mm long. Is there a way to convert all the measurements.
42 REPLIES 42
Message 2 of 43
JDMather
in reply to: gphillips
You might be able to go into Parameters and multiply all of the dimensions or change all of the units. And Tools>Document Settings>Units tab.
Another method would be to Derive Component into a new part with Scale (I would only use this method if the part dimensions are set in stone).
Message 3 of 43
There isn't a "fix this problem" command that will specifically convert a
metric part to the eqivalent numer of inches. One millimeter is 0.03937
inches so multiplying 1 mm by 25.4 would give you 1 inch.
If you open an empty part file (use the inch template) exit sketch and then
use the DERIVE COMPONENT command and apply a scale factor of 25.4 you ought
to get in the ballpark. The problem will be in the significant digits of
precision. You'd be better using 25.40000048 but even that will likely
result in some "noise" out in the area where engineers don't care but
computers do...
Gary R. Smith
Autodesk Inventor Team
Portland, OR
2.33GHz 2GB IBM ThinkPad T60p; XP pro SP2
ATI Mobility FireGL V5250 driver: 8.293.1.0
Message 4 of 43
"...metric part to the eqivalent numer of inches..."
add missing u and b as required... 😞
Message 5 of 43
gphillips
Thank you so very much Gary. That worked perfectly.
Message 6 of 43
I have a similiar problem. Our company is to take control of 1500 to 2000 2004 Autocad dwgs. They will be in metric. I have been asked if they can be converted to inches. How would you approach this? I am using Inventor 2010 Pro.
Steve
Message 7 of 43
When you say 'Autocad dwgs', do you mean 2-d drawings? Do you mean they are dimensioned in metric?
-Paul Cunningham
Message 8 of 43
Yes. They will be 2D and dimensioned in metric.
Message 9 of 43
Your situation is diffeent from the original post.
What are you going to do with the dwg's in Inventor?
Message 10 of 43
They will become our product and we will control the design. I just purchased Inventor last month.
Message 11 of 43
Unless you are going to make Inventor models of the parts, and then generate Inventor drawings from the models, I'd say you probably just need to manipulate the dimension style in Autocad.
My Autocad is pretty rusty, though. You may have better luck in the Autocad discussion groups.
Message 12 of 43
BenjP
Steve,
if your plan is to draw all those parts in Inv you can just put a "mm" behind every dimension that you apply and Inv will give you the correct value in inch.
If your plan is to use the existing dwgs and convert them, I don't have an idea how that works.
BEN
Message 13 of 43
What is this group? I'm new at this forum stuff. I was thinking the way you suggested but thought there might be a quick way to convert.
Message 14 of 43
Thanks. That's good to know.
Message 15 of 43
JDMather
How much professional training did you purchase to go along with your purchase of professional software?
You can import 2d dwg into Inventor to create 3d (there is even a utility on labs to automate this) but I suggest you use the existing dwg to practice by creating from scratch in Inventor. As indicated you can start from an inch or metric template and in any file append any units needed to the values and Inventor will convert for you.
If you run into trouble start a new thread and attach your file here.
You might want to read this document http://home.pct.edu/~jmather/AU2007/MA105-1L%20Mather.pdf
Message 16 of 43
this is the Inventor forum.
listing of all Autodesk forums
http://discussion.autodesk.com/forums/
AutoCAD forums
http://discussion.autodesk.com/forums/category.jspa?categoryID=8
Message 17 of 43
Just the Essentials. I am also going to the Advanced Class in Jan. Good advice. i appreciate it.
Message 18 of 43
It is my understanding that 1" equals exactly 25.4mm
Message 19 of 43
msklein
actually it's more like 25.39..... something as Gary said. not what your school teacher told you in school. They try and make things way to simple and do not explain that.
Message 20 of 43
JDMather
>actually it's more like 25.39.....not what your school teacher told you
Can you supply a source for this information?
Autodesk Customer Advisory Groups
