I've created a circular pattern of holes on a sheet metal part and wish to control the number of occurrences using iLogic 2012. I created a parameter called HolePatternNumber to control the number of instances while the Circular Pattern Dialog Box was open. Within that same dialog box, I can change the number of instances.
How do I programatically change the total number of holes in the pattern?
How do I pragmatically suppress a particular occurrence or occurrences within the same Circular Pattern?
I've searched through all the snippets available and didn't see anything that seems to manipulate Circular Patterns. Also note that while using the Parameters Dialog Box I'm able to change the number of occurrences but the model doesn't update.
Any tips, suggestions or errata on this subject would be most welcomed!
Jim Strenk
Inventor 2012 Certified Associate
AutoCAD 2012 Certified Associate
Product Design Suite Ultimate 2012, 2013, 2014, 2015,2016, 2017
Other than THAT, Mrs. Lincoln, how was the play??
