Inventor Forum
How to construct a sketch plane on a round
4 REPLIES 4
276 Views, 4 Replies
We work with round tubing with features put in them. Mostly just holes on a round tube. I always struggle with constructing a a plane on tube, not on the tube face but on the top, bottom and sides.
I first create my tube O.D. then my tube I.D. and extrude to the length I want. After that I want to constuct a plane to add the holes features, any suggestions on the best way of doing this?
Thanks.
4 REPLIES 4
JDMather
It sounds like you have done this before, but just not happy with the process you have used so far.
Is that correct?
If yes, can you attach a file you have completed before so that someone can demonstrate an easier way.
in reply to: JDMather
Yes I have done this before by creating un-needed parts into the sketch so I can refferance off of that part/or shape. Attached is one I did that way.
JDMather
I don't understand what was difficult with that one?
But I did notice that you did not place a construction lines to keep the holec centered.  (see attached)
Oh wait a minute, I see what you did.
Why did you rotate the workplane?
You can rotate the tube instead when you place in the assembly - just like the real world.
If you need holes at many different angles on the tube -
simply create a sketch with the angles,
then click the endpoints of the angled lines and the angled lines for the workplane.
Thanks for the tip on the hole center lines.
That tube is part of an assembly where I used other pieces to create that plane. Is there a way to create that plane without having to create unwated parts?
