Inventor Forum
How to change units of material editor
10 REPLIES 10
Message 1 of 11
15944 Views, 10 Replies
How to change the units to metric in material editor? please see the attached picture
kelly.young has edited your subject line for clarity:
10 REPLIES 10
Message 2 of 11
Unfortunately, you have to change the units for the entire library.  You cannot change the units for individual materials.
To change the units, click the down arrow at the bottom left of the Material Browser and select Set Display Units. I recommend changing the units to the unit type you desire, make your changes and then change it back.
kelly.young has embedded your image for clarity.
Message 3 of 11
jorismaes
I just installed version 2019.
Any idea how to do this in 2019?
5vFvOvB
Joris
Message 4 of 11
in reply to: jorismaes
At bottom left corner of material browser.
Message 5 of 11
jorismaes
That’s my screenshot. It’s gone...
Joris
Message 6 of 11
johnsonshiue
Hi! The dialog does not look like Inventor Material Browser. It looks like AutoCAD Material Browser. Is it true?
I am not aware of a  way to change unit display in AutoCAD Material Browser. But, you can do that in Inventor Material Browser.
Many thanks!
Software Test Engineer
Message 7 of 11
jorismaes
in reply to: johnsonshiue
I am using autocad. For all people, except US residents, feet are the things under our legs we put in shoes and make us move.
Why is it so hard to let people work in metric units?
Joris
Message 8 of 11
johnsonshiue
Hi! Let's not get political here. Unit is to make sense of a given measurement. There is no right or wrong unit. If you have suggestions to AutoCAD, you may want to go AutoCAD forum (https://forums.autodesk.com/t5/autocad-forum/bd-p/706). There are a lot of AutoCAD experts to help you.
Many thanks!
Message 9 of 11
jorismaes
I am not political. Units are things to measure, not to convince.
But let's be honest:
MapOfCountriesNotMetric-800px
But, with this, my problem isn't solved. How can I use metric units in the autocad material palette?
And...
I received this link from the autodesk help on twitter, but I'll ask it again on the autocad board.
Joris
Message 10 of 11
leowarren34
If you want to stay in metric set it to your default by configuring the default template by clicking on the gear on the advanced section of templates.
Leo Warren
Autodesk Student Ambassador Diamond
Please accept as solution and give likes if applicable.
Message 11 of 11
in reply to: leowarren34
Even if the photo is stamp size, changing the template settings to metric /iso solved this issue for me.
