How can I do this in Iventror 2014? Also, I downloaded an Inventor model of a Bimba stainless steel pneumatic cylinder and the material is the default 1.0 g/cm^3. I would like to change this to stainless steel so at least my assembly weight is correct. When I open any of the individula components everythig in the ribbon is grayed out and I can't edit it.
Solved by JDMather. Go to Solution.
Is this a part model or an assembly? Either way, if you open it or place it from thr CC, it will be read only. You have two options:
1. Open the model from the CC "As Custom", and save it someplace. Then open if from that location, and you should be able to edit the material and anything else you need. Save the file. Now edit the part in the CC, right click on the family and select Replace Family Template, then select the modified part as the new family template.
2. You can edit the family table in the CC and add a column called Material which is mapped to Inventor Property Project.Material. Then select the material you want, and when you place the part from the CC, the material iproperty on the part will take that value.
In either case, if you have instances of this part places anywhere already, you will need to refresh them to take on the changes.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
thank you for the answer to the first part of my question. Now if someone could help me with the second part regarding changing the material of the Bimba cylinder parts from default to stainless. I have attached a screen shot that showes the ribbon grayed out.
Attach the file here and end all doubt.
Since this is an off-the-shelf part, can't you simple save as STEP file and open the STEP file to add material properties?
I saved it as a stp file changed the material. When I tried to save it as an ipt Inventor would not let me replace the original file so I just added an x at the end of the name and I am on my way. Thanks everyone for the help.
Ed
