I have generated frame that has 100 members in it. Is there a quicker way of changing G_L unit to a mm so that I don't have to go into all 100 parts to change the custom properties?
also I do not need unit string to be appear in my BOM.
Please see attached image & please help
Solved by cbenner. Go to Solution.
Are you the Vault administrator? You will need the permissions for yourself adjusted to include the role" Content Center Editor". If you ARE the admin, I would also add "Content Center Administrator". Then you should be able to add or change anything in the CC that you want. If you are not the Admin, talk to that person and they can adjust your roles to let you do this.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
