Hello Dear Inventor Gurus,
Can you teach me how to create an end mill as shown from the attached pdf file?
WIll appreciate any kind of help.
Thanks a lot,
Jerome
Is this just for show (simplified) or a precise model for manufacture?
Can you attach your ipt file of what you have tried so far?
Hi JDMather,
Thanks for the superfast response.
this is will be a manufacturing model so we need it precisely as indicated from specifications.
I am still starting to create the ipt (see image) and I found it to be very challenging.
Thanks again for the help.
regards
Jerome
When you have more than a cylinder done - post back with your attempt.
You might take a look at the twist drill here http://www.cbliss.com for some ideas on how to get started.
Hi jeromecastaneda,
Here is an example that you can use as a guide. Just use the browser to follow how the features were made. You'll need to pull the the End Of Part marker in the browser down to expose the features in this model. I've rolled it up to make the file smaller for downloading.
I didn't see where you mentioned the version of Inventor you're using, but this file was created with Inventor 2010, so you should be able open it judging from your screen shot.
I hope this helps.
Curtis
I appreciate your help Curtis however this is different from the pdf drawing.
Again thanks for the help.
Cheers
Jerome
Thanks JD
are you referring to the iTwist Drill.ipt?
I'm still visualizing how I can use the parameters in the pdf to create the helix profile cut.
Do you have a suggestion how I can match the section profile for helix against the pdf drawing data?
Cheers
Jerome
Hi jeromecastaneda,
Indeed it is. The attached model was just a file I had on hand, but if you examine the fluted loft cuts and how they were made, it should provide some insight into how you will create the flute cut features for your part.
I hope this helps.
Curtis
Hi JD,
Can you check the attached part file that I've created? I'm not sure about the section C-C and B-B based from the pdf that I send as well as Detail D.
How do you smoothen the transition between the shank and cut length?
Thanks a lot
Jerome
Sketch Det_D is not constrained.
You might want to read this document before continuing further
http://home.pct.edu/~jmather/skillsusa%20university.pdf
For the rest of the geometry - it will take some time for someone to go through and verify that it is correct.
I would be very careful about the Coil command (it could be right - I haven't checked yet) as it doesn't necessarily return the same geometry as would be made in the manufacturing process of this part (a moving cutting tool along a path - refering to the manufacture of this part, not the fact that it is itself ultimately a cutting tool).
Thanks JD,
Good point. My feedback is that the details in Detail D drawing is not sufficient to contrain the sketch. What do you think?
Regards
Jerome
You can always add dimensions\constraints to fully constrain even if you only have "ballpark" numbers for now.
For example - the fillet groove would be cut using a standard cutter (much like the one you are trying to model) and/or ground with a standard radius - so you can start to fill in the missing information.
Surely someone else manufactures these tools, can you measure a competitors product?
But the question of only that radius brings me back to the Coil feature - does it really product the profile the actuall manufacturing tool creates? (this gets into an old and long discussion about sweeping a solid along a path rather than simply a 2D profile)
