hi,
how to copy the feature and how to paste that feature in some location. if any procedure.please share with me.
regards,
ram.
Right click copy, right click paste.
or
make iFeature.
Attach your file here if you can't figure it out.
hi JDmather,
i did what you repleied but, i can't position the feature.
in delta direction ( X,Y ,Z). if you have any presentation let me know.
Attach your file here.
hi,
i have attached file here. i need multiple copy and uneven distance to copy the hole feature .
thanks ,
ram
It is not clear to me what you are trying to do.
Can you finish the part with any technique so that the design intent is clear.
There is no need to copy the hole feature, since hole features can include multiple locations.
Edit Sketch1 and add your additional hole centers. Then edit Hole1 and select the new centers.
sam,
for example i used hole feature. but if we will create slot, boss etc., that time how we can place the copy feature in different places.
thanks,
regards,
ram.
hi JDmather,
you know move feature how it works. we can put value delta direction ( X,Y,Z).
but we can't use same in copy feature option.in copy feature option we can copy the feature and paste the one plane. thereafter ,how we can give the value. again we have to constrain. then what is use of this option.
thanks ,
regards,
ram
After copying the feature, right click in the graphics area and select Paste. This box displays:
Now follow the prompts, starting with "Pick Profile Plane". Then you will see a transformation glyph which allows you to position and rotate the copied feature, then click the Finish button. The feature is now placed, and has its own sketch which you can edit to precisely postion the new feature.
