Inventor Forum
How do you delete Origin Indicator?
24 REPLIES 24
Message 1 of 25
Infoseeker
15133 Views, 24 Replies
This is ridiculous.
Left click + delete does not work.
Right click, no delete option.
24 REPLIES 24
Message 2 of 25
mflayler2
in reply to: Infoseeker
I assume you mean the XYZ triad.
You turn it off in your Application Options.
Display Tab or Sketch Tab depending on which triad you are talking about.
Mark Flayler - Engagement Engineer
IMAGINiT Manufacturing Solutions Blog: https://resources.imaginit.com/manufacturing-solutions-blog
Message 3 of 25
cwhetten
I think you mean for ordinate dimensions in the drawing environment, right?
Right-click the symbol and click on "Hide Origin Indicator".
Message 4 of 25
Infoseeker
in reply to: cwhetten
I assumed if I have to create/define it, later I can delete it instead of hiding it.
But I can only hide it...
I see...
Thanks.
Message 5 of 25
cwhetten
The view remembers where you set the origin, so if you create more ordinate dims later, they will use the same (hidden) origin.  If you need to change where the origin is, you can drag it to a new place.
If you have decided that you don't want ordinate dims at all in a particular view, you'll just have to hide the origin, since there is no way (that I know of) to delete it.  Or if this really bugs you to have a hidden origin, I guess you could delete your view and re-create it.
Message 6 of 25
mpharr
Using 2013 and still no way that I see to delete the origin indicator. First time using this type of dimension and I don't see why there is not an option to delete and replace the indicator instead of moving it. Side note is there any reason that you can't place the origin indicator on an included plane? Don't seem to be able to "snap" to these lines using a section view either.
Message 7 of 25
mcgyvr
in reply to: mpharr
Just use "ordinate set" instead of "ordinate" (expand the flyout to find ordinate set)
No need for an origin indicator with that..
Message 8 of 25
jtbuckley1120
in reply to: mcgyvr
This has botherd me for some time... Allot of people do use the ordinat dimension function that creates the origin indicator. I on the other
hand I do not like or use that (the Ordinate dimension set is a much better route for a few reason i need not mention here..) so, as a team member
of several people (most of which who do not even know there are the two ways)  I get a detail to finish.  I want it with the ordinate set... I delete the existing dims that come from a origin point that needs to change in many cases and here needs to be an intersection of a sideview hole centerline and a surface.(which is an intersection that the Indicator will not even attach to) What I end up with is having to make sure that all the ord dims are part of my set so that none of the numbers are using that constantly popping back up indicator that cannot get to the Zero I am using .. (dangereuos and just plain not good)  make it possible to delete.. please..
Message 9 of 25
JDMather
in reply to: jtbuckley1120
@jtbuckley1120 wrote:
...  make it possible to delete.. please..
http://forums.autodesk.com/t5/inventor-ideastation/idb-p/v1232
Message 10 of 25
suomenvaimennin
in reply to: JDMather
Still in 2016 it can't be deleted and it periodically reappears for no good reason. This a flaw, pure and simple. Fix it!
Message 11 of 25
JDMather
in reply to: suomenvaimennin
http://forums.autodesk.com/t5/inventor-ideas/idb-p/v1232/tab/most-recent
Message 12 of 25
mcgyvr
Just updating this post with a correct link to the ideastation post..
Go here to vote to have the ability to delete the origin indicator..
https://forums.autodesk.com/t5/inventor-ideas/origin-indicator/idi-p/6346811
Message 13 of 25
mdavis22569
in reply to: mcgyvr
I just up'd it ..
They archived mine ..
http://forums.autodesk.com/t5/inventor-ideas/ordinate-elevation-option/idi-p/6304373
Sucks, as it was needed when working with elevations ... especially waste water plants ....
Mike Davis
Message 14 of 25
patel
Hey
Place one more sketch on the same part drawing then draw simple line on it and move the origin symbol to that line and delete the sktech. I hope it works.
Message 15 of 25
SBix26
in reply to: patel
Very nice workaround!  Still need to be able to delete the view origin directly, but this works nicely in the meantime.
Sam B
Inventor Pro 2021.2.1 | Windows 10 Home 2004
LinkedIn
Message 16 of 25
mluterman
in reply to: patel
Genius level right here.
Message 17 of 25
Mark this as solution! thanks
Message 18 of 25
rhasell
in reply to: patel
Thank you. Very clever workaround.
Reg
2024.2
Please Accept as a solution / Kudos
Message 19 of 25
Unintuitive workarounds like this are not fixes. This still need to be fixed correctly.
Message 20 of 25
Shawn1000
in reply to: patel
Bravo! Great work around. I've been looking for a solution for this for many years.  The fact that this issue , which is by far from trivial, and has lingered for so long, is not a good reflection of Autodesk's commitment to Inventor.  Please fix it. This glitch has caused a lot of rework over the many years it's been an issue.
