If I understand you correctly, even though the c-line through all the
holes is not parallel to the edge, you want to dimension the holes
center-to-center, perpendicular to the edge of the part.
The attached file illustrates one way this can be done. The holes along
the right edge of the part are not parallel to the edge. Place
centerlines in each hole you want to dimension, RMB on centerline, edit,
select 'align to edge'. Now when you dimension between c-lines the
dimension will measure hole to hole, perpendicular to the edge of the part.
Lester Martin wrote:
> Hi
> I want to dimension 2 holes that are on a 15 degree angle and the dimension
> is to be inline with a
> line on a 12 degree angle.
> How is this done.
Hal Gwin
Mechanical Designer
Xenogen
W2K SP4
Dell Precision 650
Dual 2.66 GHz Xeon
1.5 GB DDR
Quadro4 900 XGL
nVidia 6.14.10.4403 w/registry update
Dell UltraSharp 19" LCD
