Inventor Forum
How do I export BOM to an excel spreadsheet?
4 REPLIES 4
NickHorton8970
13060 Views, 4 Replies
I am trying to export some data from my BOM. I require the part names, quantities and lengths. I have followed a previous topic in these discussions which is now closed. it seems simple to follow but requires me to click on the export BOM icon in the top left of the browser. In my instance this is greyed out. Does anyone know of a reason why this would be?
4 REPLIES 4
blair
in reply to: NickHorton8970
Activate on the of other tabs, Stuctured or Parts and you will be able to export. I do a sort by part number and renumber before I export.
Also great software is BOMxTractor from: www.cbliss.com/icode  you need navigate to the Inventor section (it'sfree).
You don't need to open IV,just need access to the IAM files.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
NickHorton8970
in reply to: blair
No luck 1. It is still greyed out 2. The model window is also blank. I'll try the other suggestion. Thanks Managing Director Pacegrade Limited Unit 1 Providence Street Lye West Midlands DY9 8HL Tel: 01384 422246 Fax: 01384 895041.
blair
You do need to select the tab, then RMB on the tab to bring up the Enable/Dis-Able box. Then select the "Enable" and you should be able to export.
Delta Tau Chi ΔΤΧ
Raider_71
in reply to: blair
Hi you could try BOM Tools for Inventor. It can export the Inventor BOM Part parameters, Properties and thumbnail images to Excel.
http://www.mgfx.co.za/tools-for-inventor.htm
Cheers
