I have the ISO Content Center Library installed and I can get things out of it. Trouble is, I do not know what is in it. If I search for "circlip" I get zero hits. "Fastener" finds me roll pins. What do they put in these libraries?
Solved by pcrawley. Go to Solution.
Go to the "Tools" tab > Content Center Editor - and when the dialog opens, there's a drop-down menu listing all the libraries you have loaded. The default setting for this says "Merged View".
Pick the drop-down and select say the ISO library. Now you'll see only those components in the ISO library. Expand the tree on the left of the dialog box to see all the categories. I think you'll find circlips under Shaft Parts > Circlips (and there's only one external circlip in the ISO library - ISO464).
Thanks pcrawley.
I found it on the "Manage" Tab in 2015
and when you open it you need to click the "Tree View" button (1)
And I found my 30mm Outside circlip complete with dimensions (2). It's hard to believe that they only go down to 30mm. My project needs some 25mm outside circlips. I'll ask about that in another thread to keep things simple.
Thanks again.
