Inventor Forum
How do I do this in sheetmetal?
2 REPLIES 2
115 Views, 2 Replies
I need to make a sheetmetal part (from 0.035 Stainless
Steel) which is a long rectangular sheet (about 3 by 22
inches) with a long rectangular slot (about 1 by 12
inches) centered along the length, and then the sheet
bent with a 4.5 inch radius into a U-shape. This item
will be the side of a chamber, and the slot will be
a window into the chamber.
I have started with creating the U-shape bent sheet
by creating the two legs of the U and then adding a
'full-radius' bend between them to create the curve
of the U. This works fine.
Now how do I put in the slot? It does not seem to
be something that I can draw onto a plane and then
project onto the curve of the U and get what I want.
I was going to draw the profile of the slot and sweep
it around the U, but the sweep command does not seem to
be available.
What I would like is to draw this sheet as a flat
pattern and then have Inventor bend it!
Thanks for any help,
Scott
* Scott Coburn
* Brookhaven National Laboratory
* This message brought to you by Linux.
2 REPLIES 2
When you sketch, project the FLAT PATTERN and make
your cut with the CUT ACROSS BEND option.
Does that work?
Rui
I
(about 1 by 12
sheet
will
a window into the
chamber.
by
Now how do
want.
it
be
available.
pattern
Thanks for any
help,
Scott
* Scott Coburn
Laboratory
Start with the piece flat with the slot in it, draw a bend line on the part,
fold it 180° with a bend radius of 4.5.
-Mike
