Inventor Forum
How can I select the workplane which is include in the DrawingDocument with API?
2 REPLIES 2
Stakin
346 Views, 2 Replies
hi everyone,
 If i made a workplane include in a drawingdocument with api, then it will display in the view as a center line.
I want add some note to the Center line,but i didn't know hao to select it with api,
Is there have the API function to do this work?
2 REPLIES 2
MartinBernat
in reply to: Stakin
you can access the included workplane (projected as a line) as a regular centerline. Following code should work:
Sub CenterlineTest()
  Dim oDoc As DrawingDocument
  Set oDoc = ThisApplication.ActiveDocument
  Dim oCenterLine As Centerline
  Set oCenterLine = oDoc.Sheets(1).Centerlines(1)
  ' Do whatever with the centerline
  oCenterLine.Visible = False
End Sub
Thanks for your post,
Martin Bernat
Stakin
in reply to: MartinBernat
Thanks very much.
It is work perfectly.
But if i project a lot of workplane as centerline,
 and I only particularly concern one or two of them
Can I select the centerline from the DrawingDocument's Model Browser?
