I created 2 holes in the assembly mode from a sketch.I then added 4 more centre points to the sketch and when i re-opened up the same hole Tool it allows me to select the points which displays the 4 extra holes but it does not create the holes.Once holes are created in the assembly mode cannot more be added to the same sketch/hole feature?
In picture first holes were created but the second holes after altering the sketch do not appear.
I could not reproduce this behavior in r2014 SP1.
What version of Inventor are you using?
Can you attach an assembly here that exhibits this behavior?
