Hi, I am using iLogic to create two different sets of holes on a rail.
The first set of holes is a rectangular pattern. The number of instances of the pattern is determined by the overall length of the pattern. The holes are evenly spaced across the entire rail.
The second set of holes consists of two holes, spaced 1/3 of the total length from the ends of the part.
As I am testing my rule, I am noticing that occasionally my holes will interfere with each other, since parts of both sets are inline with each other.
Is there a way I can use iLogic or some other inventor tool to prevent this interferance?
Thanks for the quick response and filetype advice.
The Holes are .39" diameter, and I would say that a 0.75" minimum spacing would be ideal.
I will include an image of my part so that you can see it.
Thanks again
