Inventor Forum
Hole patching problem (part derived from assembly)
3 REPLIES 3
427 Views, 3 Replies
I have a part file derived from an assembly in order to patch holes (simplify the geometry for an electrostatic simulation). Unfortunately any time I made changes to the skeleton file which drives the asembly, and update the derived part file, the hole patching range jumps back to its default values: min=10mm, max=999999mm, which means that ALL of my holes disappear, even the big ones which are an important feature of my geometry. I need to set it every time manually again. I consider this is a bug unless there is an explanation why this must be like that.
Thank you
Daniel
Inventor 2014
Tags (1)
3 REPLIES 3
MingweiGao
Hi Daniel,
I have a try but I cannot reproduce your problem. Can you share your dataset to me and I can do some investigation of it? My email address is Mingwei.gaoATautodeskDOTcom
Steven Gao
Sr. SQA Engineer
in reply to: MingweiGao
Sorry for bumping a rather old thread, but was there any solution to this issue?
I am seeing the same problem here now and can't make it work....
Well it was some time ago but as far as I remember there was no solution and I kept resetting the parameters manually.
Daniel
