Hi, I have a punched part but in the drawing cannot insert a hole view table with the punched features. Can somebody help me out?
Solved by johnsonshiue. Go to Solution.
Strange enough that on a older version drawing I could see a hole table with similar punch features and also the IV help side says that the punch iFeatures have to come in a hole view table(the standard coloumn tabel indicates also to punch created table)....
Hi! The workflow is not as straight forward as it could be. The workflow has not been changed. You need to do the followings.
1) The view must be based on flat pattern, not folded model. You need to recreate the base view in the drawing.
2) Check "Recover Punch Center" option in the Base View dialog.
3) Hole Table -> Hole (View) -> pick a point on the view to place the origin -> pick a place for the table. The table will look empty because Punch centers are not captured by default.
4) Double-click on the table -> Options -> check "Punch centers" in Included Features -> OK.
5) If you always want to include "Punch centers" in the hole table, you can go to Manage -> Styles Editor -> Hole Table -> Options and change the defaults there.
Thanks!
Thanks John. The mark on punch centres made the whole difference. But why I get not in the table the punch ID tag? How can I bring it on? Can I edit it?
