I like to export IPT images (Wireframes with Visible Edges Only) to documents and manuals, but I would like to hide lines where radii meet flat planar features in order to keep the image clean.
Any suggestions?
Thank you.
Solved by mcgyvr. Go to Solution.
Solved by blair. Go to Solution.
The ONLY way that I know of is to drop that part into a drawing and then hide the lines you don't want..
It should give you exactly what you want..
There is no other way that I know of..
