However if you already have it done and just want to turn off the edges I
think
tools/app options/display/
and uncheck active edge display
Sean Dotson, PE
http://www.sdotson.com
Check the Inventor FAQ for most common questions
http://www.sdotson.com/faq.html
"Jeff Howard" wrote in message
news:C514A1106A1A114B01DEC587680BDD43@in.WebX.maYIadrTaRb...
> Guessing what you are seeing is the tangent line on the faces (your path
is a
> line and an arc?) If you use a spline for the path there is no
discontinuity
> in curvature (which a tangent intersection is) and no broken (by the
tangent
> line) faces.
> "Jimmy J" wrote in message
> news:CBFB21AE9A821F8445BD84ADAA39E361@in.WebX.maYIadrTaRb...
> Consider just a very simple sweep feature - sweeping a model that
resembles
> a "candy cane," or a "hook" or "walking cane." Just a letter "J" on your
> keyboard.
> After sweep, I can see where the straight region turns into a curve.
> Basically, there is a visible profile line at the intersection between the
> curved section and the straight section.
> How do I remove that to make it look all homo?
