Inventor Forum
Help with Scaling a part
8 REPLIES 8
Message 1 of 9
SteveFrey
359 Views, 8 Replies
I copied a sketch from autocad to inventor but the scale is way off for whatever reason.  I want to scale the part which is currently measuring 33" down to 2-5/8".  I can't seem to do this.  Can someone tell me how this is done?  Thanks.
Steve Frey
Inventor 2021
Windows 10 Professional 64-bit
HP ZBook 17 G6
Processor: Intel(R) Core(TM) i9-9880H CPU @ 2.30GHz
Memory: 80 GB
NVIDIA Quadro RTX5000
3D Connexion SpaceMouse Wireless
8 REPLIES 8
Message 2 of 9
JDMather
in reply to: SteveFrey
Create a sketch block and then scale the block.
Attach your file here if you can't figure it out.
Oops,  I read this wrong.
Do you want to Scale a Part (Derived Component)?
or
Do you want to Scale a Sketch?
The CADWhisperer YouTube Channel
Message 3 of 9
SteveFrey
in reply to: JDMather
I want to scale the part to 2.625".  I was fooling around with it but couldn't figure this out.  I guess I want to scale the sketch?  See attached.  Thanks.
Steve Frey
Inventor 2021
HP ZBook 17 G6
Memory: 80 GB
Message 4 of 9
SteveFrey
Would Derive be a better way to go about this?
Steve Frey
Inventor 2021
HP ZBook 17 G6
Memory: 80 GB
Message 5 of 9
JDMather
I think I told you wrong.
Scale the sketch and then turn it into a sketch block (not needed, but for safety).
But why is it the wrong scale.
This appears to be a scale problem on inserting from AutoCAD.
I would drill down the source of the problem.
Message 6 of 9
Jon.Dean
As JDMather said, you need to fix the problem in AutoCAD. Open the drawing in AutoCAD and check the units.
Attach the drawing and we can all have a look at it.
Cheers
Jon.
Jon Dean
Message 7 of 9
MSD1
in reply to: Jon.Dean
All I am trying to find out is how to scale something that currently measures 66mm to measure 2.625".  Attached is the file.  It is showing the mm dimension in inches once inported into Inventor.
Message 8 of 9
JDMather
in reply to: MSD1
The dwg file indicates that it was drawn in the wrong units.
But it is trivially easy to scale the sketch as indicated above.
Message 9 of 9
MSD1
in reply to: MSD1
Never mind, I figured it out.  Thanks.
