Inventor Forum
Help with Loft
12 REPLIES 12
Message 1 of 13
CAD-One
487 Views, 12 Replies
Help with Loft
I am trying hard to loft this. i cant understand why it would not?
Can any of you figure this out for me, please.
C1
Inventor Professional 2020
Vault Professional 2020
AutoCAD 2020
12 REPLIES 12
Message 2 of 13
CCarreiras
in reply to: CAD-One
Hi!
You need a loft, but not as you are thinking, i guess.
Its better do one part and then make a circular pattern to achive all part
I dont have Inv 2013, so i 'm sending you the model in step format.
But i can explain how to do it, if you will.
Did you find this reply helpful ? If so, use the  Mark Solutions!  Accept as Solution or Give Kudos!Kudos - Thank you!
CCarreiras
Message 3 of 13
CCarreiras
in reply to: CCarreiras
Hi!
Just a print screen with the result and operations.
CCarreiras
Message 4 of 13
CAD-One
Mindblowing !
I was wondering if there was any error in my sketches.
Kindly expand the (+) for the loft feature. I want to know which sketched you used, please.
Again, thanks for your help Carlos.
C1
AutoCAD 2020
Message 5 of 13
CAD-One
Nevermind!
I got it, thanks again.
C1
AutoCAD 2020
Message 6 of 13
CCarreiras
Hi!
It's a little moere then this.
First objective: create the surface with loft.
1 - Create a construction plane (chose the central axis and a poin of the octahedron near your "vertical" skecth2)
2 - Open sketch2 and copy the geometry
3 - Create new sketch (sketch8 in the image) and paste the geometry. Transform the copyed geometry in "block" to maintain the form intact.
project the points from both tetahedrons and conect the copyed geometry to these two projected points.
4- Now you have two sketches (your in red iand the new in blue), you can perform the loft: open the loft tool, change to surface mode and chose both sketches.
Now you have a nice surface. End of first objective.
CCarreiras
Message 7 of 13
WHolzwarth
Here's another idea. (2013 file)
Walter
Walter Holzwarth
Message 8 of 13
CAD-One
in reply to: WHolzwarth
WH-Thanks for showing different approach.
C1
AutoCAD 2020
Message 9 of 13
karthur1
And yet a simplier approach.  I am using 2015, but here is a video of how I did it.
http://screencast.com/t/ElkjjApoNz
Kirk
Message 10 of 13
CAD-One
in reply to: karthur1
Art - I should say its nice & simple with out involving surfacing tools. Thanks.
C1
AutoCAD 2020
Message 11 of 13
CAD-One
Had some difficulty with top of the pole. was able to manage though. Here is a final model.
Thanks for the support.
C1
AutoCAD 2020
Message 12 of 13
karthur1
Nice.
Message 13 of 13
johnsonshiue
Hi! The part can be created using Loft feature. However, it cannot be done in just one Loft. It requires multiple Lofts. Loft has an internal restriction on how the face should behave along the section progressing direciton. The faces in that direction has to maintain smoothness (at least tangent continuous or curvature continuous).
Thanks!
Software Test Engineer
