I am trying to make a 3d sketch into a solid. After trying everything I can think of, I admit defeat. Can someone tell me how to turn this thing into a solid?
Solved by CCarreiras. Go to Solution.
Hi Anuvin,
These links might help also:
http://www.inventortales.com/2012/10/all-for-fun-creating-20-sided_26.html
http://www.inventortales.com/2012/11/all-for-fun-again-modeling-12-sided-die.html
http://www.inventortales.com/2012/11/for-little-more-fun-10-sided-die.html
http://www.inventortales.com/2012/11/and-yet-again-all-for-fun-8-sided-die.html
I hope this helps.
Curtis
Thanks guys, that worked. I started from that blog, but ran into trouble when it came to the patching. I tried patching before I posted.
The thing is, I was having a really hard time selecting just a single line of the previous patch. I couldn't figure out how to do it. It seemed like if I put the model at an extreme angle I had an easier time singling out the line I wanted.
Did you have a smiliar experience while putting together that post for me?
