Inventor General Discussion
Active Member
rjones0215
Message 1 of 9 (1,251 Views)
Help drawing a cutterhead for a dredge
1251 Views, 8 Replies
10-01-2011 07:47 AM
I am trying to draw this cutterhead.  The 3D sketch and helical curve commands have a allowed me to create part of the "arms" with the teeth on them but I can't seem to get them to come up and over the hub in the middle.  Only to the top of it.  Any tips?  Thanks.
Inventor 2013 Certified Professional
JDMather
Message 2 of 9 (1,243 Views)
Re: Help drawing a cutterhead for a dredge
10-01-2011 09:29 AM in reply to: rjones0215
Attach your ipt file here.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
Active Member
rjones0215
Message 3 of 9 (1,239 Views)
10-01-2011 11:31 AM in reply to: rjones0215
JDMather
Message 4 of 9 (1,235 Views)
10-01-2011 12:29 PM in reply to: rjones0215
Why did you use Driven rather than Driving dimensions in Sketch10?
I would have used the edge of a Coil surface body rather than the 3D sketch - much easier to control.
I would avoid adaptivity for this design.
Sketch12 is not constrained.
You might start with this document http://home.pct.edu/~jmather/skillsusa%20university.pdf
I suspect I would Thicken a trimmed helical surface.
JDMather
Message 5 of 9 (1,227 Views)
10-01-2011 06:59 PM in reply to: JDMather
Do you have a picture from side and top?  You have an assembly - do you have a 2D drawing from which it was made?
JDMather
Message 6 of 9 (1,200 Views)
10-02-2011 11:14 AM in reply to: JDMather
Here is an alternate solution - more information would be needed to get precise representation.
JDMather
Message 7 of 9 (1,151 Views)
10-03-2011 06:43 AM in reply to: JDMather
Have you made an progress on this?
Active Member
rjones0215
Message 8 of 9 (1,121 Views)
10-03-2011 08:31 AM in reply to: rjones0215
I had to move to something else but will be back on the cutterhead later this week.  Thanks for your input.  I will be keeping you involved with my progress.  And I'm sure I will have more questions for you.
Active Member
rjones0215
Message 9 of 9 (778 Views)
11-09-2012 11:35 AM in reply to: rjones0215
Mr. Mather,
I realize it's been awhile since I submitted my original post about help with cutter head model.  Since then I have made progress in accomplishing a decent model, but I still think there is a better way to create my cutter head.  I'm attaching the file so that you may view it.  Any input or pointers at all would be greatly appreciated.  Also, I am aware that I have a few sketches that are not constrained.  I am still getting acquainted with 3D sketches.  Thanks again for any info.
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
