Inventor Forum
Help Inventor-AutoCAD Mechanical dwg
5 REPLIES 5
simon_head
225 Views, 5 Replies
I design complex assemblies and wish to create detail drawings with complex annotation. Inventor is a pain with 2D annotation- its just not good enough for the work I do. What I wish to do is to create the views in Inventor and then save the views as an AutoCAD dwg and the annotate with AutoCAD 2002 Mechanical. When I do this the views are saved but when I wish to manipulate the data each view seems to be non explodable to edit and each entity is in the form of a thick polyline.
How can I export the views from Inventor to AutoCAD to enable me to annotate the drawing. This should not be a problem as the relationship to the model at this stage should be broken. I wish to be able to edit all entities
Thanks for the reply (in anticipation)
Simon Head
Engineering Manager, Moorfield Associates
5 REPLIES 5
in reply to: simon_head
Simon, the views you are seeing Mechanical are as you said non explodable blocks. But what they are are groups. Email me and I will send you a vba file that will explode all the groups in a drawing. Michael.best@rts-group.com
Hit the LWT button at the bottom of the drawing. There was a lisp routine that fixes some
of the issues people have with IDW to DWG stuff, but it looks like it might not be
available any more.?? Maybe someone has a copy they can share?
http://www.synexus.ca/utility/ivdwgconv/
Kent
Member of the Autodesk Discussion Forum Moderator Program
"simon_head" wrote in message
news:f125556.-1@WebX.maYIadrTaRb...
> Simon Head
I've seen this before myself, not sure if there's a setting in Inv to
disable it or not.
Inventor exports assys to dwg as AutoCAD "Groups", use the "group" command
and explode the group(s), that should allow individual entity selection for
edit etc.
I haven't seen it in awhile, possably because I've not exported any assys
recently.
Don't give up on Inventor's detailing capability, it takes time to acclimate
to but it does get easier.
Hope this helped.
R Coleman
Mechanical Designer
Schulte Distinctive Storage
simon_head wrote in message
I design complex assemblies.............
Simon Head
you can still download it from Drews site, mymcad.com, goto "must have"
Mike
good. BTW I got that link from a old post but it is also referenced at Drew's site.
Not sure if Dave took it down or ??
Kent
"MDB" wrote in message news:f125556.3@WebX.maYIadrTaRb...
> Mike
