Inventor General Discussion
Valued Contributor
Justin_Desilva
Message 1 of 4 (599 Views)
Help - How to hide dimensions in sketches
599 Views, 3 Replies
08-20-2012 06:15 AM
I'm working with a series of 3D sketches. Some sketches must remain visible as reference. While creating the sketches, the dimension call-outs grow too distracting from the linear sketches. Is it possible to hide, or toggle off/on the dimensions while leaving the sketch geometry visible?
*Pro
ampster
Message 2 of 4 (596 Views)
Re: Help - How to hide dimensions in sketches
08-20-2012 06:27 AM in reply to: Justin_Desilva
right click on the sketch in the browser and choose hide dimensions.
Valued Contributor
Justin_Desilva
Message 3 of 4 (589 Views)
08-20-2012 06:50 AM in reply to: ampster
Aha, that was the option I was searching for.
1. Right click the sketch in the feature manager
2. Select Dimension Visiblity
I'm curious if I can create a short-cut key to toggle the dimension on/off? Is it possible to create a custom keyboard key?
*Pro
jletcher
Message 4 of 4 (585 Views)
08-20-2012 07:01 AM in reply to: Justin_Desilva
I am sure you can find or make a macro to do this this way it does it to all sketches.
James Letcher
2012 Factory Design Suite ( will not load 2013)
What happen to my Inventor :-(
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
