First, we have learned that IDE RAID arrays can compete on equal terms with
single SCSI drives in a number of applications.
Second, we saw that different disk subsystems proved better in different
tasks: SCSI drives are best working under their native server workloads while
IDE drives in RAID0 arrays do sequential read and write very well.
Third, we discovered a coefficient between SCSI and IDE drives: one Cheetah
X15 36LP equals at least four Maxtor 6L020J1 :).
It's clear that every interface has its own advantages and shortcomings. SCSI
means reliability and high performance, but also high price. Moreover, it needs
a costly controller. IDE means huge capacities and much lower storage cost for
1MB than in SCSI HDDs. But IDE drives are much less reliable and to build a
fault-tolerant disk subsystem you need to combine them into mirror RAID arrays
(and this requires at least one more drive and a RAID-controller)."
For your setup, since you are accessing your files via a network, SCSI would
not offer any additional (or noticable) performance. Your swapfile would be
faster, but if you are using it for your work, the problem is not Hard disk
speed but not enough RAM. The major advantage that SCSI has is increased
reliablity and 5 year warranty, vs IDE has one year warranty (on most) and low
reliability. So what do people do? Most my customers choose to go for a $100
RAID card and two IDE HDDs for RAID 1, and buy 2 Gigs of RAM!
Ashley Fulks
Production Manager @
href="http://www.nisku.ca">www.nisku.ca
Specialized Supercomputers for
Inventor
href="http://www.nisku.ca/autocomp.htm">http://www.nisku.ca/autocomp.htm
href="http://www.nisku.ca/autocomp/autocompII.html">http://www.nisku.ca/autocomp/autocompII.html
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
"bsmith75" <I
href="mailto:bsmithsmith@cardone.com">bsmithsmith@cardone.com> wrote in
message
href="news:f148dfa.-1@WebX.maYIadrTaRb">news:f148dfa.-1@WebX.maYIadrTaRb...
putting together a Req for new workstations and was wondering how much "bang
for my buck" I would get by using SCSI over IDE hard drives, when using
Inventor 6. My VAR stressed useing SCSI hard drives, just wondering how much
of a differance I will see
"Matt Stocking" <
href="mailto:mstocking@remove-nospam.xtech-outside.com">mstocking@remove-nospam.xtech-outside.com>
wrote in message
href="news:16EA25241A9C1E1F3412EFA2EB37AD75@in.WebX.maYIadrTaRb">news:16EA25241A9C1E1F3412EFA2EB3......
why not just scsi and duals 🙂
wait, dual scsi's in raid 0 with duals would be
the best. ok now i know thats too much
"Ashley Fulks" <
href="mailto:ashley@nisku.ca">ashley@nisku.ca> wrote in message
href="news:1E8FAE65FC7B137928FA0EDDAE4DF0FE@in.WebX.maYIadrTaRb">news:1E8FAE65FC7B137928FA0EDDAE4......
Well if money's no object, i would go SCSI fiber
channel with Fiber channel card. You can get 2 Gigabits per second hard drive
transfer speed! * drool *
and of course Dual 3.06 Ghz Xeons with
Hyperthreading and 4 Gigs RAMBUS 1066, 1 gig network card, 52 inch plasma
screen...
Ashley Fulks
Inventor
"Matt Stocking" <
href="mailto:mstocking@remove-nospam.xtech-outside.com">mstocking@remove-nospam.xtech-outside.c...>
wrote in message
href="news:16EA25241A9C1E1F3412EFA2EB37AD75@in.WebX.maYIadrTaRb">news:16EA25241A9C1E1F3412EFA2E......
"Keith Panik" <
href="mailto:kpanik1234@pxauto123.com">kpanik1234@pxauto123.com> wrote
in message
href="news:A1654757625B01049E2518E16CA0039A@in.WebX.maYIadrTaRb">news:A1654757625B01049E2518E16CA......
Do you really need hyperthreading if you have a
dually? I thought hyperthreading simulated dual processors with 1
CPU.
just curious,
kp
"Curiosity killed the cat & satisfaction
brought him back"
"Ashley Fulks" <
href="news:1E8FAE65FC7B137928FA0EDDAE4DF0FE@in.WebX.maYIadrTaRb">news:1E8FAE65FC7B137928FA0EDDA......
fiber channel with Fiber channel card. You can get 2 Gigabits per second
hard drive transfer speed! * drool *
screen...
Ashley Fulks
for Inventor
href="http://www.nisku.ca/autocomp/autocompII.html">http://www.nisku.ca/autocomp/autocompII.htm...
"Matt Stocking" <
href="mailto:mstocking@remove-nospam.xtech-outside.com">mstocking@remove-nospam.xtech-outside...>
wrote in message
href="news:16EA25241A9C1E1F3412EFA2EB37AD75@in.WebX.maYIadrTaRb">news:16EA25241A9C1E1F3412EFA......
be the best. ok now i know thats too much
"bsmith75" <I
message
"Stan McLean" <
href="mailto:smclean@sympatico.ca">smclean@sympatico.ca> wrote in
message
href="news:D6CF34FD18C67A71FFF812245302186C@in.WebX.maYIadrTaRb">news:D6CF34FD18C67A71FFF81224530......
Just to add my 2 cents
Last year I benchmarked 2 computers.
1) Clone - AMD 1.8 single processor, 1 gig DDR
(266) ram, 7200 rpm IDE hard drive. Geforce 3 64 meg graphic
card.
2) Xeon - dual 1.7 with 1 gig pc800 ram, SCSI
hard drive, Wildcat 5110 128 meg graphic card.
Testing was done with Inventor 5.3 and PacWest
demo set from Autodesk. It takes approx 600 megs of ram to load the full
assembly. I tested loading time of the assembly, Precise view
generations of the assembly in IDW and Zoom and rotate speeds of the full
assembly.
size=2>------------------------------------------------------------------------------------
Loading time - 20 seconds for
AMD ---- 23 seconds for Xeon
Although the SCSI hard drive was faster - loading
the assembly into memory took more time with the PC800 memory than the DDR on
the AMD
size=2>-------------------------------------------------------------------------------------------
Zoom rotate - Xeon was approx 30% faster than the
AMD
Advantage to Wildcat over the Geforce 3, but for
the price difference I want more bang for my buck.
size=2>---------------------------------------------------------------------------------------------
Precise view generation - 5 min 47
seconds for AMD ----- 8 min 12 sec
Xeon
Xeon should have the clear advantage with
the dual processor over the single processor AMD, but this number crunching
test just showed AMD clear advantage.
size=2>------------------------------------------------------------------------------------------------
Final test was again number crunching - 1800
frame rendering in 3D Studio Viz - 1 hour 12 minutes AMD , 1
hour 45 minutes for the Xeon.
Stan McLean
"bsmith75" <I
in message
