Inventor Forum
HELP
6 REPLIES 6
blackghostrider22
336 Views, 6 Replies
HELP
I Just downloaded a student version of Autodesk inventor professional 2012 and I need help changing a file type from 2012 to a 2011 file type, how do I do that?
6 REPLIES 6
mcgyvr
in reply to: blackghostrider22
Your only option is to export as a step or iges file and open in 2011..
Once a file has been saved in a newer version it can no longer be directly opened in an older version... 3d cad programs in general are not backward compatible.
Once you get the part back into 2011 via the use of a neutral file format like STEP (*.stp) it will be a base solid (no feature tree).
You can still edit using any of the usual tools.
If you need to recover the feature tree for some reason you can do this with the free Feature Recognition add-in avialable here http://labs.autodesk.com
john.laidler
in reply to: JDMather
You can't change the file version type to 2011.... and there is no 'save as' functionality.  STEP is your option, but you will lose the intelligence.  It will be converted to a 'base' model.
John Laidler
AutoCAD, Inventor and Vault
Please use "Accept as Solution" & give "Kudos" if this response helped you.
JDMather
in reply to: john.laidler
@jclaidler wrote:
....and there is no 'save as' functionality.
Of course there is.  Go back and read the previous responses to the original question.
john.laidler
uh.. no, actually there is no 'save as Inventor 2011' function.
John Laidler
Correct.... 🙂 you get the Gold Star.
____________________________________________________________
Dennis Jeffrey, Author and Manufacturing Trainer, Autodesk Inventor Certified Expert
Autodesk Manufacturing Implementation Certified Expert
Autodesk Silver Manufacturing Partner
Subscribe to the free digital "The Creative Inventor Magazine" now available at: http://teknigroup....
XP64 SP2, GeForce 9800GT-1GB, Driver: 6.14.12.7061, 8GB Ram, AMD Athlon II 3.2 Ghz
Laptop: Win7-64 Pro, 4GB, ATI Graphics on board, 2012 Ultimate, IV2011 or 2010 Pro, all SP's
