My weld caterpillar isn't showing up the same from weld to weld. The welds are all the same size. The two highlighted welds are separate features referencing the same dimension for size. This display problem seems inconsistent as well, sometimes they show right and other times after a change to the model they don't. Any ideas to how I can fix this display problem.
NVIDIA Quatro Pro
Solved by mercerc. Go to Solution.
Hello, and thank you for the reply. I have never used the pack and go feature so I hope the attached files will be enough for you to evaluate the problem. I'm using Inventor professional 14. We are subscription based. As you can see in the image below the problem still exists and is inconsistant.
Thank you for the files as it confirmed a suspicion I had. That was the Caterpillar size that was used was different in the welds you pointed out. The ones that looked correct had a width of .125, those that looked short used a width that was .045. What was curious was that when I edit the Weld Caterpillars it had the width gray out as it was selectable. So in my case I deleted them and redid them.
You can access the caterpillar edit by right clicking on the caterpillar and selecting edit caterpillar. As you can see in the second image fill the width in your file wasn't editable and to configure the symbol to your needs I needed to delete it and replace it. You can add caterpillars by going to the symbol section of the annotate ribbon and selecting caterpillar.
OK, thank you. I appreciate you looking into this for me.
