Inventor Forum
HELP!! Sheet Metal Flat Model
10 REPLIES 10
Message 1 of 11
rnewcomb
769 Views, 10 Replies
IS there a way to use the flat model of a sheet metal part?
I want to save only the flat model from the IPT file and use it to build a die.
10 REPLIES 10
Message 2 of 11
chad38
in reply to: rnewcomb
You could always use the "unbend" command, and save as to a new part name?
HP Z420 Workstation
Intel Xeon CPU E5-1603 0 @ 2.80 GHz 2.80 GHz
12.0 GB RAM
Windows 7 Professional 64 Bit
3D Connexion Space Pilot
Solid Edge ST9 MP1
Inventor Professional 2015
Autocad 2015
SolidWorks 2015
Message 3 of 11
rnewcomb
in reply to: chad38
Would you know how to make a model of a blower side with a venturi which is a revolved feature and have it flatten for a flat pattern??
I'll send file for you to look at.
Rod
Message 4 of 11
chad38
No idea how to go about getting a true flat pattern for a feature like in the part file you attached. No idea at all. However, if you were open to changing the way the part is constructed, you could make an assembly with 2 parts. First part being the flat face, and the second part perhaps composed of lofted flanges?
HP Z420 Workstation
12.0 GB RAM
Solid Edge ST9 MP1
Autocad 2015
SolidWorks 2015
Message 5 of 11
rnewcomb
in reply to: chad38
I do not mind changing the way we constuct the part at all, I am very open.
right now we make two files, one that is only the flat for the drawing flat pattern and cnc file and one that is the formed to use for the assembly model of the enire blower. I am really wanting to be able to make this of one ipt and then have it flatten.
By having two files we have to make sure we edit both files when we need to make a change, which is something I would like to change.
Message 6 of 11
chad38
Actually, now that I've thought about it a bit more, I'm not even sure that feature can be made in any way that can flatten out....because you say this is for a venturi, I assume that step-bending would not be an option for that feature. I think someone with a bit more experience in this software may be needed to look and say whether this feature can be created in a way that is flattenable in Inventor.
HP Z420 Workstation
12.0 GB RAM
Solid Edge ST9 MP1
Autocad 2015
SolidWorks 2015
Message 7 of 11
rnewcomb
in reply to: chad38
Well Chad, I appreciate your interes and help
I have looked for this for a while now and it just doesn't seem to be something that can be done. oh well
again thank you
Rod
Message 8 of 11
CCarreiras
Hi!
No flat for this part... this is a plastic deformation, inventor only calculate bend deformation.
Did you find this reply helpful ? If so, use the  Mark Solutions!  Accept as Solution or Give Kudos!Kudos - Thank you!
CCarreiras
Message 9 of 11
rnewcomb
in reply to: CCarreiras
This is a sheet metal die formed part, there should be a way to do this in Inventor, the data is in the model
Message 10 of 11
chad38
If we were using Solid Edge, I could do it no problem. I think this is one more thing that Inventor needs to invent a way to do this. But more than that they need to do a "normal cutout" function in sheet metal......and that cut across bend thing is total junk you shouldn't have to go that far just to create a simple cutout.
HP Z420 Workstation
12.0 GB RAM
Solid Edge ST9 MP1
Autocad 2015
SolidWorks 2015
Message 11 of 11
rnewcomb
in reply to: chad38
I am going to have to post this question to Autodesk and see what they say
